![](/sites/default/files/styles/product_image/public/product_images/PatMooneySawsPegasusCNC.jpg?itok=lsacb8cl)
Pat Mooney Inc., The Saw Company announces a new addition to its FMB line of automatic band saws, the Pegasus CNC. The Pegasus CNC is designed for mitre sawing from 0 to 60 degrees in automatic cycle. The CNC control will allow users to set a cut length and cutting angle for each step in a cycle. For the initial cycle a workpiece, for instance, can be indexed to 32" length and cut at 0 degrees, while the second cycle has been programmed for a 64" length and cut angle at 45 degrees. The unique design of the saw head combines a special aluminum alloy with steel and cast iron for a balanced saw head that absorbs cutting vibrations. The height return of the saw band is set automatically to the workpiece. Also, the rotation of the saw head is fully programmable from the machine control panel.The rotation is powered by hydraulic cylinder and the cutting angle maintained via magnetic band. Once the saw head is at the desired cutting angle, the saw head is locked into position via hydraulic cylinder. Other features include dynamometric band tension to ensure consistent blade tension; blade rotation sensor that monitors the band wheels; saw blade drive and blade speed control that features an enclosed direct drive gear box for long-life performance; and saw blade feed system with dual controls for feed and speed. The CNC allows 99 cutting programs to be stored with each program having 100 steps (number of cuts and cut length). Desired cut length is input and if more than one index required, CNC will automatically calculate the required number of strokes and blade kerf calculation.
- bandsaw blade ( band)
Endless band, normally with serrated teeth, that serves as the cutting tool for cutoff or contour band machines.
- feed
- kerf
kerf
Width of cut left after a blade or tool makes a pass.
- sawing
sawing
- sawing machine ( saw)
