Full grip pie jaws are made from extruded aluminum
Dillon says that its full grip jaws manufactured from 6061 extruded aluminum bar stock eliminate the porosity inherent with castings, thus increasing their strength, reliability, and safety.
October 3, 2025
Available in diameters up to 28", they can be modified to heights of 10" and widths that exceed the chuck face diameter for increased capacity. Maximum contact area from the full grip jaws provides a solid gripping surface, which yields more friction for drive with reduced part distortion. They are ideal for high-speed machining, as well as precision boring, tapping, drilling, and finishing across virtually all industrial markets.
In addition to 6061 extruded aluminum, Dillon Full Grip Pie Jaws are available in brass, 1018 steel, and cast iron. Custom designs available with special heights, diameters, and configurations, including a matching serration location which is exactly perpendicular to the slots.
Dillon Chuck Jaws can provide both standard and special pie jaws in 1.5mm x 60°, 3.0mm x 60°, 1/16th x 90°, and 3/32 x90° serrations, American standard and metric tongue and groove, and acme and square serrated key type mounting interfaces.
