G-Force Cut-off Blades
September 13, 2013
NAP Gladu is introducing a new line of disposable saw blades to the metal market. G-FORCE blades are a complete line of top quality disposable saw blades for high-speed cut-off machines such as Tsune, Nishijima, Amada, Kasto and others. This application and blade design is quickly taking the place of bandsaw operations, according to the company.
G-FORCE blades are available with cermet or carbide tips to suit a wide range of cutting applications. Their thin kerf and optimally sized tips maximize yield and minimize cutting pressures; so G-FORCE blades reportedly require less horsepower, run quieter and reduce bearing and machine loads. They also feature a curved face design for rapid chip removal, providing a cleaner, more accurate cut.
  • bandsaw
    bandsaw
    Machine that utilizes an endless band, normally with serrated teeth, for cutoff or contour sawing. See saw, sawing machine.
  • kerf
    kerf
    Width of cut left after a blade or tool makes a pass.
  • sawing machine ( saw)
Sponsored Content
