The new Walter G4014-P grooving tool holder is ideal for small part machining operations such as swiss type machining. The system offers an innovative new “SmartLock” insert clamping feature to access the clamping screw from the side.
This makes it possible to change inserts in the machine – even where space is limited—in particular on long center lathes and multi-spindle machines. As a result, changing inserts is approximately 70% faster. The clamping forces are around 30% higher than those of existing tools in the market, increasing the stability and enabling users to achieve a significantly longer tool life. The clamping screw can be accessed from either left or right side; thus, the operation of the tool from either side is possible, making it a very flexible system.
The patent-pending positive engagement design of the insert seat also contributes to the flexibility. The cutting insert is seated in the insert pocket with an innovative prismatic design. This prevents incorrect engagement, especially for narrow insert widths, and enables an extremely high level of indexing accuracy. The Walter grooving system consisting of G4014-P and DX18 inserts is available in the shank sizes of ½- 5/8 in. and 10–20 mm, with insert widths from 0.059-0.118 in. (1.5–3 mm) and for parting off diameters of up to 1.38 in. (35 mm).
The holder designs are offered with either precision cooling on the rake and flank faces or without internal cooling. These special features make the system the current benchmark in terms of the mass production of small parts like shafts, plug contacts, nozzles or implants. Typical applications include automotive suppliers, medical engineering as well as the electronics, food processing, watchmaking and general engineering industries.
When used in lathe or screw-machine operations, this process separates a completed part from chuck-held or collet-fed stock by means of a very narrow, flat-end cutting, or parting, tool.
Because of the ground chip breaker on these inserts, the inserts are handed (left hand and right hand insert), but these are standard ISO shapes and sizes- so they are held in conventional ISO turning holders. The inserts also use ‘M’ or maximum material condition tolerance on the corner radii of…
Walter expanded the TC630 Supreme product range to include UNJC4 to UNJC9/16, UNJF4 to UNJF9/16 and MJ3 to MJ10 thread sizes. Optional internal coolant is available for thread sizes starting from MJ4, UNJF8 and UNJC8 to provide effective chip removal on deep threads.
The Paradur® Ti Plus taps are for threading blind holes with a geometry specially developed for machining titanium alloys with a tensile strength of at least 700 N/mm2 using emulsion instead of oil. The Prototex® TiNi Plus tap is effective for through-hole threading. Walter specially developed the…
The M5250 cutter is effective for milling steel, cast iron, stainless steel, aluminum and other non-ferrous metals (ISO P, K, M and N workpiece groups), as well as materials with difficult cutting properties. Unlike other full-effective helical milling cutters, the XTRA∙TEC® XT M5250 can also be…
The TC685 Supreme cutter is a left-hand cutting tool that features a 15° helix angle for excellent chip removal. Cooling with compressed air makes it possible to achieve maximum tool life in materials harder than 50 HRC. Additionally, internal coolant delivery is available for tools that create the…
MA230 Advance milling cutters adapt to most ISO materials and milling approaches. The extensive range includes options like corner radius, corner chamfers, reduced neck, and unequal helix. The helix pitch is meticulously aligned with the number of teeth, ensuring unmatched running smoothness. Your…
The MC166 Advance solid carbide milling cutter with increased core stability compared to a conventional tool core ensures a consistently reliable machining process even in unattended operations. A differential pitch provides optimum operational smoothness and significantly extends tool life.
The holders accept CCGT3xx, DCGT3xx and VCGT2xx indexable inserts and provide a high level of indexing accuracy even when turning parts with tight tolerance specifications. The short head dimension enables short clamping and high stability. The shank dimensions are 12 mm × 12 mm and 16 mm × 16 mm.
With the ability to cut blind-hole threads up to 3.5 × DN, the TC130 Supreme tap is targeted for applications in general mechanical engineering and the energy industry, such as for threading wind turbines. The tap is suitable for threading steel and cast iron (ISO P and K workpiece groups). Also,…
Both WKP01G and WPP05G grades are ideal for continuous cutting and occasional interrupted cuts in high tensile materials (approx. 280-410 HB or 130-200 ksi). Ideal applications include large-scale production of components for the automotive and energy industries, such as gearboxes, gears and rotor…
