Gas Cylinder Cart
Gas Cylinder Cart
Strong Hand Tools announces the new cylinder cart for the safe handling of heavy gas cylinders. The self-supporting four-wheel base of the new gas cylinder cart provides a safe and stable method for the transport, lifting and placement of heavy gas cylinders while minimizing the effort required for heavy cylinder handling.
October 17, 2019
Easily transport cylinders around the work area with smooth maneuverability, even in tight areas. Safely lift and place cylinders onto welding carts, pallets or other elevated platforms up to 7" in height. Workers should not attempt to lift cylinders manually or "roll" cylinders. The new cylinder cart eliminates the potentially dangerous and difficult job of moving and lifting cylinders.
The adjustable stainless steel keeper bar holds the cylinder securely in place without the use of damaging, hard to use chains or straps.
