Gas Struts
Gas Struts
Engineering components and parts manufacturer, WDS Component Parts Ltd. has extended its range of gas struts with new stroke lengths and options. The company can provide standard gas struts by overnight delivery or work with customers to develop bespoke units that match their application needs.
December 13, 2018
The extended range now offers stroke lengths between 20mm to 500mm. Rod and body sizes are available from 6mm rod diameter coupled with 15mm body diameter to 14mm rod with 28mm body. The actuation forces available range from 20N to 2,500N, depending on the size of the gas strut.
Each strut is fitted with an adjusting valve so that the internal pressure can be pre-set to the requirements of the application. Once the strut is installed the valve can be used to re-adjust the pressure in situ.
An extended range of end fittings are available, including clevis pin, clevis eye and angle joints. These can be fitted by WDS or supplied separately.
Carbon steel is the usual choice of construction material for the body of the gas struts, but a 316 stainless steel option is available for arduous-duty applications.
