GCB10-5 Deep Cut Bandsaw
The Bosch GCB10-5 Deep Cut bandsaw is the easy-to-handle tool to deliver low-spark, clean cuts in rebar, conduit and other metals. These precise cuts require limited rework because the 10-amp saw is powerful enough to handle professional-sized jobs on most materials.
September 7, 2017
The Bosch GCB10-5 has a 10-amp motor, which delivers precise cuts in everything from rebar to copper pipe, from steel track to threaded rod. The bandsaw saves time by making clean cuts that require almost no rework for burrs or tempering colors. It accommodates most common applications in a single pass thanks to a cutting depth of up to 4-3/4 in.
The tool is ergonomically designed and weighs only 14.5 lbs., allowing it to provide efficient performance in a compact package. The bandsaw also includes a saw hook for during-the-job storage and an LED light to illuminate the cut line for greater accuracy.
"The Bosch GCB10-5 Deep Cut bandsaw offers the light weight and compactness that users demand on the jobsite," said Mike Iezzi, product manager, Robert Bosch Tool Corp. "For most applications in electrical, mechanical, plumbing or construction trades, 4-3/4" depth more than gets the job done. It's a great tool – versatile enough for dozens of tasks on the jobsite."
The Deep Cut bandsaw provides nearly spark-free cuts for safer metalcutting operation. It features variable-speed settings, so the user can match the cut rate to the material for greater precision. Settings start at 100 sfm and go up to 380 sfm.
With a compact design and weight of less than 15 pounds, this bandsaw is suitable for cutting tough metal in difficult areas or for extended overhead applications. The main handle provides a comfortable grip for cutting in various positions. It also has a carry handle for easy transport.
