Gen4 Four Outlet Selectable Voltage Power Supply
Applications using up to four Gen4 Super Ion Air Knives, Ion Air Guns, Ion Air Cannons, Ionizing Bars or any other EXAIR Gen4 static eliminator product can be connected to one power supply. Like all EXAIR Gen4 products, these four outlet power supplies are UL component recognized, CE and RoHS compliant.
October 15, 2020
EXAIR's new Gen4 Four Outlet Selectable Voltage Power Supply allows you to choose input voltages of 115VAC or 230VAC. Four 5kV stainless steel output connectors can energize four static eliminators at the same time. Applications using up to four Gen4 Super Ion Air Knives, Ion Air Guns, Ion Air Cannons, Ionizing Bars or any other EXAIR Gen4 static eliminator product can be connected to one power supply. Like all EXAIR Gen4 products, these four outlet power supplies are UL component recognized, CE and RoHS compliant.
They also feature an electromagnetically shielded modular power supply cable which eases routing and connections. An integrated fuse on the primary protects against voltage spikes. The lighted power switch indicates operation and is field replaceable. The Gen4 Four Outlet Power Supply is housed in a durable metal enclosure (6" L x 4.0" W x 4.4" H) that is ideal for rugged, industrial environments. Gen4 static eliminators having a bayonet-style connector can be inserted into the power supply where the electrical connection is made deep inside to prevent a shock hazard.
Gen4 static eliminator products using this power supply are all shockless and have armored high voltage cables which resist abrasion and cuts.
