Gen4 Two Outlet Selectable Voltage Power Supply
EXAIR's new Gen4 two outlet selectable voltage power supply allows you to choose input voltages of 115VAC or 230VAC. Two 5kV stainless steel output connectors can energize two static eliminators.
January 14, 2020
EXAIR's new Gen4 two outlet selectable voltage power supply allows you to choose input voltages of 115VAC or 230VAC. Two 5kV stainless steel output connectors can energize two static eliminators. Applications using up to two Gen4 Super Ion Air Knives, Ion Air Guns, Ion Air Cannons, Ionizing Bars or any other EXAIR Gen4 static eliminator product can be connected to one power supply. Like all EXAIR Gen4 products, these two outlet power supplies are UL component recognized, CE and RoHS compliant.
They also feature an electromagnetically shielded modular power supply cable, which eases routing and connections. An integrated fuse on the primary protects against voltage spikes. The lighted power switch indicates operation and is field replaceable. The Gen4 power supply is housed in a durable metal enclosure (5.5" L x 4.0" W x 3.4" H) that is suitable for rugged, industrial environments. Gen4 static eliminators having a bayonet-style connector can be inserted into the power supply where the electrical connection is made deep inside to prevent a shock hazard.
Gen4 static eliminator products for the power supply are all shockless and have armored high voltage cables, which resists abrasion and cuts.
