General-Purpose Drill Line
The general-purpose drill line from Dormer Pramet includes the Precision Twist Drill brand of Silver & Deming drills. These reduced-shank drills deliver versatility and reliability.
June 22, 2016
The Precision Twist Drill R56 features a ½ inch diameter round shank suitable for use with ½ inch chuck portable drills. The common flute and overall length allows for minimal adjustments for drill presses. It is ideal for drilling a wide range of materials of low to medium tensile strength.
The Precision Twist Drill R57 features 3 flats on the ½ inch diameter shank for a more positive non-slip hold.
The Precision Twist Drill R56CO is manufactured from premium cobalt steel for increased hardness, wear resistance and heat resistance. It features a 118° self-centering split point for accurate positioning and easier penetration. The R56CO is the ideal drill for tough, high tensile strength materials that generate higher cutting temperatures, such as high alloy steels, ferrous castings, stainless and other difficult-to-machine materials.
  • tensile strength
    In tensile testing, the ratio of maximum load to original cross-sectional area. Also called ultimate strength. Compare with yield strength.
  • wear resistance
  • alloy steels
    Steel containing specified quantities of alloying elements (other than carbon and the commonly accepted amounts of manganese, sulfur and phosphorus) added to cause changes in the m…
  • twist drill
    Most common type of drill, having two or more cutting edges, and having helical grooves adjacent thereto for the passage of chips and for admitting coolant to the cutting edges. Tw…
