GENOS L3000-M One-Saddle Lathe
Okuma says its new GENOS L3000-M one-saddle lathe is strong, fast and ideal for cutting a range of exotic materials with ease. The integral spindle motor provides increased machining capacity and rigid guideways handle powerful cutting capabilities.
September 1, 2016
The GENOS L3000-M has high speed milling, and Y-axis options on specific models allowing users to select the best specifications for a particular workpiece length and shape. Shop floor productivity is increased with a mounted NC tailstock that allows for easy setup of various workpieces. TAS-C (Thermo Active Stabilizer) construction is standard and automatically compensates thermal effects to maintain tight tolerances.
The GENOS L3000-M is an operator-friendly designed machine that simplifies cleaning, filtration and maintenance tasks. User-friendly features include:
  • A separate cooling tank for quick servicing
  • Easy spindle access to reduce operator work burden and maintenance tasks
  • Reduced chip accumulation during long, continuous runs decreases machine downtime for cleaning.
Key features of Okuma's GENOS L3000-M horizontal lathe:
Max Turning Diameter/Length (in) Ø 11.8
Spindle Nose/Chuck (in) A2-8 /10
RPM Range 38~3,800
Tailstock NC: MT#5
Rapid Traverse (X/Z), ipm 984/1,180
Floor Space (in) 98 x 74
Weight (lb) 11,023
