GENOS M560-V Vertical Machining Center
GENOS M560-V Vertical toolchanger. See automatic toolchanger." title="CNC machine tool capable of drilling, reaming, tapping, milling and boring. Normally comes with an automatic toolchanger. See automatic toolchanger." aria-label="Glossary: machining center">Machining Center
The new GENOS M560-V vertical machining center from Okuma America Corp. combines a new high column design and CAT 40 BIG-PLUS spindle to cut large, complex parts. The large work envelope minimizes restrictions on workpieces, tool lengths and the rotary table.
The new GENOS M560-V vertical toolchanger. See automatic toolchanger." title="CNC machine tool capable of drilling, reaming, tapping, milling and boring. Normally comes with an automatic toolchanger. See automatic toolchanger." aria-label="Glossary: machining center">machining center from Okuma America Corp. combines a new high column design and CAT 40 BIG-PLUS spindle to cut large, complex parts. The large work envelope minimizes restrictions on workpieces, tool lengths and the rotary table. A rigid, thermally stable, double-column construction gives this CNC machine the ability to withstand thermal deformation, resulting in improved machining performance. It's also one of the heaviest machines in its class.
A 30-hp spindle with 146 ft. lbs. of torque allows this machine to cut challenging metals such as titanium and Inconel, as well as stainless steel and aluminum. A separate automatic toolchanger door makes tool changing seamless without interrupting the machining process. The table moves only in Y, while the spindle moves in X and Z, enabling a smaller machine footprint, rapid feed rates, precise cutting and smooth surface finishes.
Thermo-Friendly Concept, Okuma's proprietary thermal deformation compensation technology is standard on this machine. Pretension ball screws and bi-directional spindle cooling allow for better control of the machining process. Optional Collision Avoidance and Machining Navi Intelligent Technologies are available.
Key Specs of the GENOS M560-V VMC
- Max Machining Volume mm (in) 1,050x560x460 (41.34x22.05x18.11)
- Table Sizemm (in) 560x1300 (22.05x51.18)
- Max. Load Capacity kg (lbs) 900 (1,980)
- Spindle Speed min⁻¹ 15,000
- Spindle Motor Power kW (hp) 22/18.5 (30/25)
- Rapid Traverse m/min (ipm) X-Y 40, Z: 32 (X-Y: 1,575, Z: 1,262)
- Magazine Capacity 32 Tools
