![](/sites/default/files/styles/product_image/public/product_images/1013-Gi-360.jpg?itok=zGf9d5S9)
The Gi-360 T (tilt) high-speed laser inspection system from General Inspection provides a host of benefits.
With Lasers perpendicular to part the lasers will produce more accurate images equating to higher resolution of data, which will allow for tighter tolerance reporting.
Improved machine repeatability.
Laser head vertical adjustment to center part axis about laser sender/receiver points.
Better part anchoring points of the image in the software.
Better handling/increased range of longer parts.
Increased range of stepped/tapered (cone) parts.
Tilt head works in conjunction with virtual tilt software.
Optional servo positioning.
Right angle, direct rotation drive and straight up vertical drive.
Improved sealing to computer drawer.
Capable of forward (15 degrees) and reverse (3 degrees) tilting.
- tolerance
tolerance
