GN 115.7 Zinc Die-Cast Door Handles
J.W. Winco Inc. offers GN 115.7 zinc die-cast door handles with a latch mechanism in metric sizes.
September 1, 2014
These RoHS-compliant door handles are used when the application requires both a locking mechanism and a handle. A rotary movement limited to 90 degrees, e.g. of the triangular spindle of type DK, shifts the key-bolt behind the doorframe. The key-bolt is beveled, making the door-closing action easier. The choice of 22 differently shaped catch plates provides a range of latching distances from 4 to 50mm, or 0.157 to 1.97 inches.
Door handles are made of die-cast zinc, with a powder coated textured finish in either black or silver. Lock hardware is zinc-plated steel with a blue passivated finish. Available types of latch designs offered are triangular spindle, with square spindle A/F 7, square spindle A/F 8, screwdriver slot, and double bit.
