GN 223 Steel Control Levers with Round Through-Bore
November 28, 2017
JW Winco Inc. announced it has available GN 223 steel control levers with round through-bore, with or without keyway and square through-bore versions.
These RoHS compliant control levers, offered standard in metric sizes, feature a steel hub and arm with a black oxide finish, while the ball knob is black phenolic plastic with a glossy finish. Inch size bores, keyways, and setscrew holes are available upon request.
The GN 223 steel control levers perform smoothly and powerfully thanks to the heavy-duty arm of the lever.
  • black oxide
    black oxide
    Black finish on a metal produced by immersing it in hot oxidizing salts or salt solutions.
Sponsored Content
