GN 227.4 A4 Stainless Steel Spoked Handwheels
J.W. Winco Inc. offers GN 227.4 A4 stainless steel spoked handwheels, in inch and metric sizes, with and without revolving handle.
August 1, 2014
These RoHS-compliant handwheels, often used where a noncorrosive component is necessary, are renowned for their high mechanical strength and are not affected by shock and knocks. They are of an attractive design and shape at a reasonable cost, according to the company.
Handwheel body is pressed A4 (AISI 316L) stainless steel, with a shot blast satin finish. Solid hub is also made of A4 (AISIS 316L) stainless steel, welded to body. Inch size versions are available with round bore without keyway. Metric sizes are offered with round bore without keyway, round bore with keyway, and square bore. Various additional bore sizes, keyways, set screw holes are also available upon request. Diameters range from 160 to 400mm (6.3 to15.74 inches).
