GN 237 Zinc Die-Cast Hinges
J.W. Winco Inc. offers GN 237 zinc die-cast hinges with extended hinge wing, countersunk through-holes or threaded stud type. These RoHS-compliant hinges with extended hinge wings, used when wider spacing is required on the mounting surface for the bore holes, have a compact and sturdy design.
The hinge body is zinc die-cast, with either a black powder coated, textured finish or silver powder coated, textured finish. The hinge pin and threaded studs type are stainless steel. Various metric and inch size fasteners and kit packaging available upon request.
