J.W. Winco Inc. offers GN 254 inch and metric size stainless steel vibration/shock-absorption mounts, conical type. These RoHS compliant vibration/shock absorption mounts are also known as shock absorbing mounts, vibration mounts, antivibration mounts, vibration bobbins or rubber bumpers.
Frequently used as end-stop bumpers, for example with roller conveyor systems, they absorb most of the accumulated kinetic energy on impact. Acting as dampers and preventing damaging shock and rebound, they also act as sound dampers. These isolation mounts are also used as leveling feet, plus versions with 40 or 70 durometer natural rubber material are available upon request.
The mount body is made from synthetic rubber, vulcanized, 55 durometer, while the cover plate and the tapped inserts/threaded studs are stainless steel, molded in.
