GN 342.1/342.2 Steel Vibration-Damping Leveling Mounts
JW Winco Inc. offers GN 342.1/342.2 metric size, tapped and threaded, stud-type, steel, vibration-damping leveling mounts. The specified load for these RoHS compliant leveling mounts features a recommendation up to the point the damping element can be permanently subjected.
JW Winco Inc. offers GN 342.1/342.2 metric size, tapped and threaded, stud-type, steel, vibration-damping leveling mounts. The specified load for these RoHS compliant leveling mounts features a recommendation up to the point the damping element can be permanently subjected. This static load equals a thrust on the area, at which the damping material reaches its optimal dynamic dampening ability. The elastomer of the dampening element is oil resistant and has an operating range from -30° C (-22° F) to +70° C (158° F).
The leveling mounts, which cannot be disassembled, feature a base, tapped socket or threaded stud, hex nut (hex nut is included with threaded stud version), that are steel, with a zinc plated, blue passivated finish, while the damping element is antislip elastomer material in gray and glued to the base.
