GN 343.1 Leveling Mounts
J.W. Winco Inc. offers series GN 343.1 Tapped Type Steel Base Leveling Mounts with or without Plastic or Rubber Base Cap, in metric sizes.
July 13, 2013
These RoHS-compliant leveling mounts can bear high static loads, but for high loads, they should be used in conjunction with screws of high tensile strength. The base and tapped socket are zinc plated, blue passivated steel. The hex nut is zinc plated, blue passivated steel, ISO 4032.
The mounts are available without base cap, with white technopolymer plastic (DELRIN) base cap, with electrically conductive plastic base cap, with black thermoplastic TPE rubber base cap, or with electrically conductive rubber base cap.
  • tensile strength
    In tensile testing, the ratio of maximum load to original cross-sectional area. Also called ultimate strength. Compare with yield strength.
