GN 414.1 Metric Size, Steel, Safety Indexing Plungers
JW Winco Inc. offers GN 414.1 metric size, steel, safety indexing plungers with push-button, click-type lock and pin in the retracted position.
The GN 414.1 safety indexing plungers with click-type lock are used when the plunger pin is to be briefly prevented from protruding. When the pin is retracted to its end position, the button engages with a clearly audible click. The safety lock on these RoHS compliant products can be unlocked only by exerting axial pressure on the red safety push button, with the plunger pin then returning to its starting position by spring force.
The plunger body and pin are made from steel with a black oxide finish and the plunger pin is hardened. The knob is technopolymer plastic with a matte black-gray color that is not removable, while the safety push button is also made from technopolymer plastic in matte red.
