GN 425 Metric Size, Steel Round Cabinet “U” Handles
J.W. Winco Inc. offers RoHS-compliant GN 425 metric size, steel round cabinet "U" handles With tapped blind-holes.
August 8, 2017
These cabinet "U" handles come in 8, 10, 12 and 16 mm diameter with lengths ranging from 55 mm to 300 mm (depending on diameter) and are supplied with zinc-plated steel location disks for a clean and decorative look. Because of the location disks, the handles guarantee a virtually perfect mounting location, even with a bit larger holes in the cabinet. If considering for outdoor use, the stainless steel version should be given preference. Due to the manufacturing process, special sizes can be supplied at certain minimum quantities.
The handle is constructed from standard free cutting steel, with tapped holes for mounting. The handle finish can be supplied in either in a black or red powder-coated textured finish, chrome-plated finish or a blackened finish.
