GN 453.1/GN 453.2 Vibration/Shock Absorption Mounts
J.W. Winco Inc. offers GN 453.1/GN 453.2 vibration/shock absorption mounts with stainless steel components, conical type, in inch sizes.
These RoHS-compliant mounts, also known as shock absorbing mounts, vibration mounts, anti-vibration mounts, vibration bobbins, or rubber bumpers, are frequently used as end-stop bumpers, e.g., for conveyor trolleys. Absorbing most of the accumulated kinetic energy on impact, they act as dampers and prevent damaging shock and rebound, and are also used as sound dampers. They can also be used as leveling feet. The parabolic shape of these isolation mounts generates progressive resilience characteristics: Impact and shock effects are absorbed more gently.
The mount body is made of natural rubber (NR), vulcanized, 55 durometer (shore hardness +/-5°). The cover plate is stainless steel, molded" Versions with either tapped inserts or threaded studs are offered; both are made of stainless steel, molded"
