GN 702 Die-Cast Stop Locks
J.W. Winco Inc. announced it now offers series GN 702 Zinc Die-Cast Stop Locks with four indexing positions.
J.W. Winco Inc. announced it now offers series GN 702 Zinc Die-Cast Stop Locks with four indexing positions. These metric sized, RoHS-compliant stop locks offer a fast and easy way to close and hold doors, flaps, slide-in models, etc. by locking in four 90 degree positions.
Three versions are offered: with flange for surface mounting, with female thread, and with male thread. The latch on the stop locks is zinc die-cast, with black or red electrostatically applied powder coat textured finish. The indexing mechanism for the flanged and female threaded types is steel/plastic, steel parts zinc plated, blue passivated; for the male threaded type it is zinc die cast/plastic. The fastening flange is zinc die-cast with electrostatically applied powder coat in black textured finish.
In standard production, the mounting bore holes are usually made by punching or with a laser. GN 123 sheet metal punch is recommended for small series and sheet metal with a thickness less than 2mm. Mounting bore holes can also be made by drilling or milling.
