![](/sites/default/files/styles/product_image/public/product_images/_083016.jpg?itok=AT3cCLXG)
J.W. Winco Inc. announced it now has available GN 810 “universal fit,” stainless steel, vertical-acting toggle clamps with horizontal mounting base.
These vertical acting toggle clamps work according to the toggle principle, as the lever and clamping bar move in the same direction. In the clamped position, the operating lever is in its vertical position. The RoHS compliant vertical acting toggle clamps in the U-bar version with two flanged washers can accommodate an application specific clamping screw. A version including the spindle assembly with neoprene rubber tip is available as a standard. The “universal fit” base allows for both inch and metric hole pattern mounting.
All the toggle clamp’s moving parts are lubricated with a special grease. The hand grip is made from a high quality, oil resistant red plastic.
