GN 936 Slam Latches Zinc Die-Cast
JW Winco Inc. offers GN 936 slam latches zinc die-cast, with and without lock. The design of the GN 936 slam latches enable doors and closures to close effortlessly.
July 2, 2019
"The latch engages automatically when the door is closed preventing the door from opening unintentionally," said John Winkler, CEO, office of the president at JW Winco. "The slots enable the slam latch to be assembled to aluminum profile systems with different cross-sections."
The lockable versions of the slam latches are each supplied with two keys, and the key can be removed in both the open and locked positions.
The housing is zinc die-cast, powder coated, and has either a black or silver, textured finish. The cover and latch are plastic and come in either black-gray or light gray. The lock mechanism is zinc die-cast while the key is steel, nickel plated.
