![](/sites/default/files/styles/product_image/public/product_images/1113-SumitomoGND.jpg?itok=HS6ZO2oA)
New GND grooving tool holders from Sumitomo Electric Carbide Inc. are engineered to reduced chatter and eliminate vibration. Featuring high rigidity bodies and single-piece special steel construction, the GND reportedly produces less chatter and eliminates vibration.
GND tool holders also deliver steady performance for turning, profiling, facing and cut-off applications. Due to precision sintering technology, the GND tool inserts offer improved tolerance of +/-0.0012" (+/-0.03mm) for all grooving widths from 0.079" to 0.250" (2.0 to 6.0mm).
GND tool holders also provide special chipbreakers for various machining applications. Each of the six chipbreakers serves a specific purpose from turning to profiling to facing. The GND lineup features the following chipbreakers: MG, a general feed type for turning, ML, a low feed type for multi-purpose use, GG, a general feed type for grooving, GL, a low feed type for grooving, CG, a general feed type for cut-off, and RG a general feed type for profiling.
- chatter
chatter
- feed
- grooving
grooving
- profiling
profiling
- sintering
sintering
Bonding of adjacent surfaces in a mass of particles by molecular or atomic attraction on heating at high temperatures below the melting temperature of any constituent in the material. Sintering strengthens and increases the density of a powder mass and recrystallizes powder metals.
- tolerance
tolerance
- turning
