Okuma's GPW/GAW grinder series is now equipped with the intelligent OSP-P300G CNC. Okuma's open architecture OSP-P control runs on a Windows-based platform and fully integrates the machine, motors, drives and encoders, allowing for enhanced machine performance and true customization to suit particular machining needs. The Easy Operation control and touch screen increase efficiency by letting users easily and quickly toggle between machine operations, programming and wheel preparation screens.
The innovative wheelhead traverse structure gives these grinders a solid, compact footprint that saves valuable machine floor space while the user-friendly design allows various workpieces to be loaded effortlessly for easy automation in high production environments. The extremely rigid foundation allows for heavy-duty cutting and high speed grinding of 5.5kW with an optional 7.5kW.
The series is equipped with standard Chatter Control function that automatically adjusts wheel speed for accurate, stable machining. The high-speed grinding wheel spindle is ideal for cutting mass produced small parts with precision. Included in this grinder series are the GP14W, 15W, GA14W and 15W.
Key features of the GPW/GAW series:
• OSP-P300G control
• Dead center workhead (Std: C type)
• Chucking headstock (T specs standard) Tailstock quill stroke 35mm
• Wheel spindle motor: 5.5 kW (10 hp) (inverter drive)
• High feed rates X-axis ø30 m/min.; Z-axis: 20 m/min.
• uperior rigidity for powerful grinding
• Variety of loader patterns for easy automation
- chatter
chatter
- feed
- grinding
- grinding wheel
grinding wheel
