![Grade WCH10C Ceramic Inserts Coated Ceramic Inserts Deliver High Process Reliability](/sites/default/files/styles/product_image/public/product_images/WAL-527.jpg?itok=9bXvmMQh)
Walter has introduced a new line of coated ceramic indexable inserts, grade WCH10C. The new Walter grade is mixed ceramic Al2O3 + TiC, and provides cost effective machining, including hard machining. The high level of process reliability is due to the high chemical and thermal stability of the aluminum oxide base as well as the negative chamfer T-land), all promoting a strong cutting edge. They feature TiN PVD coating for improved wear detection and surface quality and are available with or without wiper geometry.
The new Walter WCH10C inserts deliver high repeat accuracy due to its sintering process and are tough and wear resistant due to the strong connection to their titanium carbide substrate. Optimum surface quality is promoted as well by their uniform grain distribution in the substrate, The new Walter coated mixed ceramic grade WCH10C inserts can be used effectively on materials ranging in hardness from 45 up to 60 HRC. The inserts can be a cost-effective alternative to CBN cutting tool materials.
Additionally, WCH10C ceramic grade can be used in case hardened materials where the insert encounters both hard and soft turning conditions simultaneously; an application where CBN usually does not succeed well.
- aluminum oxide
aluminum oxide
Aluminum oxide, also known as corundum, is used in grinding wheels. The chemical formula is Al2O3. Aluminum oxide is the base for ceramics, which are used in cutting tools for high-speed machining with light chip removal. Aluminum oxide is widely used as coating material applied to carbide substrates by chemical vapor deposition. Coated carbide inserts with Al2O3 layers withstand high cutting speeds, as well as abrasive and crater wear.
- cubic boron nitride ( CBN)
- cutting tool materials
Cutting tool materials include cemented carbides, ceramics, cermets, polycrystalline diamond, polycrystalline cubic boron nitride, some grades of tool steels and high-speed steels. See HSS, high-speed steels; PCBN, polycrystalline cubic boron nitride; PCD, polycrystalline diamond.
- hardness
hardness
- sintering
sintering
Bonding of adjacent surfaces in a mass of particles by molecular or atomic attraction on heating at high temperatures below the melting temperature of any constituent in the material. Sintering strengthens and increases the density of a powder mass and recrystallizes powder metals.
- titanium carbide ( TiC)
Extremely hard material added to tungsten carbide to reduce cratering and built-up edge. Also used as a tool coating. See coated tools.
- titanium carbide ( TiC)2
- titanium nitride ( TiN)
- turning
- wiper
wiper
