![GrindSmart 630XW, ShapeSmart NP50 Grinding Machines for the Firearm and Ammunition Industry](/sites/default/files/styles/product_image/public/product_images/630XW_new%20logo_1.jpg?itok=xKwLEtcR)
Rollomatic, a leading machine tool manufacturer based in Le Landeron, Switzerland, maintains its global leadership position in the field of multi-axis CNC grinding by presenting two grinding machines which have specific capabilities for grinding a variety of gun-related tooling and components. Rollomatic has worked with many leading manufacturers in the firearm and ammuni•on industries to develop and fine•tune grinding processes for the following fields:
Manufacturing parts for the weapons industry:
- Production grinding of firing pins
- Prototyping cylindrical parts for guns
Rifle chamber manufacturing and reconditoning:
- Chamber reamers in tungsten carbide for rifle chamber cutting
Cold forging in radial forging machines:
- Forging mandrels in high-cobalt tungsten carbide
- Forging hammer dies (in sets of 2 and 4) in tungsten carbide
Punches for ammuni•on tooling manufacturing:
- Solid carbide draw punches for bullet casing manufacturing
GrindSmart® 630XW 6-axis tool grinding machine:
- With 6-station wheel and nozzle changer
- Automatic tool loader/unloader
- Linear motion technology for improved surface finish
- Universal workhead with high-speed capability to combine high-accuracy cylindrical grinding and geometry grinding
- Large variety of workholding and tool holding solutions including custom-made fixtures
- Laser measuring included
ShapeSmart® NP50 5-axis pinch/peel cylindrical grinding machine:
- Automatic 3-axis tool loader/unloader
- Pinch/peel grinding process in combina•on with V•block part support and with simultaneous grinding of roughing and finishing passes
- Multi-pass grinding for efficient heavy stock removal
- Amazingly large diameter range from 0.0008” to 1”
- Patented non-round pinch/peel grinding for all non-round shapes such as square, rectangle, oval, corner radius and any other non-round profile
- Onboard diameter gauge included
- cylindrical grinding
Grinding operation in which the workpiece is rotated around a fixed axis while the grinding wheel is fed into the outside surface in controlled relation to the axis of rotation. The workpiece is usually cylindrical, but it may be tapered or curvilinear in profile. See centerless grinding; grinding.
- grinding
- tungsten carbide ( WC)
Intermetallic compound consisting of equal parts, by atomic weight, of tungsten and carbon. Sometimes tungsten carbide is used in reference to the cemented tungsten carbide material with cobalt added and/or with titanium carbide or tantalum carbide added. Thus, the tungsten carbide may be used to refer to pure tungsten carbide as well as co-bonded tungsten carbide, which may or may not contain added titanium carbide and/or tantalum carbide.
