GrindSmartNano5 Grinding Machine
With the GrindSmartNano5, Swiss grinding machine manufacturer Rollomatic has developed a high-performance grinding machine for the series production of dental and medical tools that not only grinds an impressive range of tools, but does so fully automatically, without any operator intervention.
January 1, 2014
Particularly in the field of medical and dental technology, small tools that can handle hard, difficult-to-machine materials such as high-performance ceramics or titanium alloys are very important. However, soft materials are also machined in this industry, e.g. during the processing of wax blanks, so versatility is a must. The GrindSmartNano5 was specifically developed in particular for dental tools. However, it is also suitable for series production of other applications. For example, it can produce dental burs, standard cutters and Lindemann milling tools as well as endodontic files and reamers.
"In order to keep cycle times as short as possible and to ensure ultra-high stability during the grinding process, the grinding machine features a compact design with minimized travel distances," explains Jean-Charles Marty, Product Manager at Rollomatic SA.
To cover such a wide range of tools, the GrindSmartNano5 is offered with different tool guide systems to suit the application. One such system, which is designed especially for dental burs, clamps the tool directly behind the head in order to achieve maximum stability during the grinding operation. The second tool guide system is suitable for manufacturing standard drilling and milling tools whose tool head diameter is smaller than the shank. For tools with long cutting length, such as endodontic files and reamers, a steady rest is available to prevent the tool from bending during the grinding process.
Changing from one tool guide system to the other and reconfiguring the machine only takes a few minutes. "In addition, the machine hood is not connected to the bed," adds Jean-Charles Marty. "This means that the grinding results cannot be influenced by external disturbances."
Rollomatic has also integrated an automatic robot loader into the GrindSmartNano5 to equip it for series production. Batch sizes of up to 1,000 pieces can be machined without operator intervention thanks to the robot. The machine has been designed for maximum efficiency, with short axis movements and a high-speed loading system that loads and unloads the workpiece in just a few seconds, resulting in significantly short cycle times.
Rollomatic supplies the GrindSmartNano5 with a powerful FANUC control unit plus an integrated PC with 15-inch touchscreen and an ergonomic control panel. The standard package also contains the latest version of the programming software Virtual GrindPro, which offers a combination of high performance and user-friendly operation. The software package, consisting of Virtual GrindPro and BurCalc, offers a range of programming options for milling and drilling tools, not just dental tools.
An office simulator shows the direct 3D display of the workpiece to be machined and also visualizes the machine movements on the PC before production begins. This helps to minimize machine setup time and avoid any potential collisions from the onset, while significantly maximizing machine operation.
Jean-Charles Marty: "Despite offering such a wide range of outstanding features, the CNC programming remains simple and intuitive for the user. Naturally, we continue providing our customers with the latest free software updates after they have purchased the GrindSmartNano5."
  • grinding machine
  • steady rest
    Supports long, thin or flexible work being turned on a lathe. Mounts on the bed’s ways and, unlike a follower rest, remains at the point where mounted. See follower rest.
