Ono Sokki Technology Inc. introduces the Model GS-1600 linear gage sensor. The GS-1600 is a slim and compact linear gage sensor that can easily be installed as a direct replacement in current production equipment and existing fixtures. This gage measures dimensions, thickness, curvature, eccentricity, displacement, height, depth, flatness, variation, runnout, roundness, distortion, deflection, and position. This gage sensor uses the proven linear glass scale technology. The main advantage of this principle is that you can maintain high consistent accuracy throughout its entire range, according to the company. The GS-1600 produces highly accurate measurements to 0.00004", and throughout its full 30mm measuring range. To add to this sensor's ruggedness, a waterproof seal was added to make it (resistance equivalent to IP-64). Also a dust bellow is provided for extra protection to enable accurate measurements in a harsher environment. Endurance testing shows this sensor may be used beyond 5 million strokes. Automated measurement is also possible by attaching an optional air lifter. If you require more than the standard 6' cable length, you can add extension cables up to 100'. The GS-1600 comes equipped with an attached 6' signal cable that can be directly connected to an array of remote displays with various outputs such as analog, RS-232C, MTI, BCD and GO/NO-GO comparator.
