GTI Wireless Measurement System
GTI Wireless Measurement System from GTI Predictive Technology is a wireless measurement device connecting to digital instruments.
November 1, 2014
GTI Wireless Measurement System from GTI Predictive Technology is a wireless measurement device connecting to digital instruments. It reads digital micrometer/dial/caliper readings and communicates wirelessly with iPhone/iPad via Bluetooth Low Energy, allowing user to view real-time plot directly on the screen of iPhone/iPad.
DialRead, DialReadPad and DialReadRotary apps are available in App Store. The system is compatible with digital instruments with SPC output from Mitutoyo, Fowler and Starrett.
Key Features:
• Dimension: 60 x 45 x 25mm
• Resolution: 0.001mm (reading from the instrument)
• Range: 12.7mm (limitation of the instrument)
• Rotating angle resolution: 1 degree
• Sampling frequency: 1 to 10 Hz
• Wireless Working Range: up to 20 m
• Working Temperature: 0 to 50 degrees C
• Battery: 850 mAh rechargeable
• Charging: 5 VDC USB and 110VAC
• Built-in rotation sensor auto detecting 360 degrees rotation
App Features:
• Display acquired data in real-time graph
• Continuous or single measurement recordings
• Built-in Rotating Angle Measure (1 degree resolution)
• Auto detect and auto stop after 360 degree rotation
• Analog rotating dial indicator on screen
• Pinch, Pan, Max, Min, Average
• TIR (total indicator reading) and threshold/indicator
• Multiple sampling rate options
• Customizable reading decimal accuracy
• Offline post processing plot and polar plot
• Record data, CSV and SQLite database
• Export via email and Dropbox synchronization
• QR Reader for Machine ID
• Quick custom PDF report with results, graphs, image, logo, signature, map and GPS location
  • micrometer
