Haas Lathe Adapters
Haas Lathe Adapters
Lockwood Products Inc. is pleased to introduce two new Lathe Adapters.
Lockwood Products Inc. is pleased to introduce two new Lathe Adapters. The frustration to switch from screw-lock spherical nozzles to the Loc-Line Modular System is over. Two versions are offered, one that will accommodate 15mm pockets and a second that will perfectly fit Haas lathes.
Both have been designed in a short and 2" long version that will allow coolant to easily reach past drill and collet chucks. Customizing your coolant flow with any of our ¼" System nozzles and accessories guarantee improved coolant flow to your work piece improving tool life and chip removal.
