Harsh-Environment Industrial Ethernet Switches Series
Mencom harsh-environment industrial Ethernet switches series provide rugged solutions to manage high-demanding advanced networks under the extreme temperature. Minimum operating temperatures for the harsh environment Ethernet switches range from -20° C to +70° C.
November 7, 2017
The unmanaged switches in this series feature up to 20 Ethernet or Gigabit ports, Relay Outputs and Profinet Packet Prioritization while the managed switches feature features Profinet CC-B compatibility. The managed switches also provide flexible advanced network management features to maximize network performance and minimize down-times, such as ERPS/RSTP ring, VLAN, QoS, and trunking. Additionally, the Gigabit switches are MIL-STD (Military Standard) certified for shock, vibration, temperature and humidity performance, and extended operating temperatures from -40° C to +85° C.
  • Unmanaged Harsh Environments Switches
5 to 10 Fast Ethernet or Gigabit Ethernet ports, embedded Power over Ethernet (PoE) on selected models, and a variety of port configurations such as RJ45, SFP, and single- or multi-mode fiber optics
Atex Zone 2 certified for using them in well areas or mines with a high risk of explosion
  • Layer-2 Managed DIN-Rail Switches
A high degree of link redundancy, low control, and configurability
Designed to withstand strictest EMC requirements of compliance level 3 and level 4
High-performance components guarantee a real-time packet switching, even on full load
  • Layer-3 Managed DIN-Rail Switches
High degree of security and Layer-3 switching capabilities
Real-time packet routing based on the local network's IP address instead of MAC address of the destination device
Strictest Industrial EMC protection in compliance with Level 3 and 4
