HBP-800AXL and HBP-800XL
A new line of bandsaws engineered to accommodate and cut large-diameter tubing quickly and efficiently is available from Behringer Saws Inc.
A new line of bandsaws engineered to accommodate and cut large-diameter tubing quickly and efficiently is available from Behringer Saws Inc. HBP-800AXL automatic and HBP-800XL semiautomatic series bandsaws allow companies to save on upfront capital expenditures and avoid buying more expensive bandsaws for everyday cutting while expanding their capability to specifically cut large tubes when needed. The HBP-800AXL and HBP-800XL bandsaws deliver all the performance and capabilities of standard HBP-800 series bandsaws, cutting solid bars and structurals up to 31.5". In addition, these new bandsaws allow for the cutting of tubes up to 39" in diameter. Companies can now purchase a lower cost bandsaw to handle day-to-day production cutting needs at the standard size range while utilizing this additional feature to accept new projects requiring the cutting of large-diameter tubing. All HBP-800 bandsaws are built with a cast iron frame construction and a twin-column parallel down feed design for proper saw blade tensioning to deliver quick, efficient and forceful low vibration cutting for smooth cuts, according to the company. These bandsaws also come with a heavy-duty roller conveyor for quick and efficient handling of heavy materials pre- and post-cut. HBP-800 bandsaws feature a frequency-controlled 14.7-hp main drive motor with a variable-speed range from 55 to 393 sfm, which is selected at the operator's control panel. Hydraulic and hardened clamping jaws on the bandsaw ensures steady and precise cuts at all speeds.
