HE Series Noncontact Interlocks
Tapeswitch Corp. offer several lines of noncontact safety switches and system solutions for machine guarding in global industrial and commercial markets.
August 13, 2013
Tapeswitch Corp. offer several lines of noncontact safety switches and system solutions for machine guarding in global industrial and commercial markets. The new line features the HE Series Interlock switches which are the latest coded magnetic noncontact switches. They feature fully encapsulated solid state, single-point switching with built-in, dual-color, LED status indication.
The switches offer a CAT 4, SIL 3 PLe safety performance level. It has 2 N/O and 1 N/C bi-directional solid state outputs. The solid state outputs offer simple series connection. They offer a 7mm switching distance and can approach on each other from most angles. The HE Series is IP67 rated.
When combined with the SCU-1 control unit, it is a multigate switch solution capable of monitoring up to 30 switches in the series. Since the HE series is a HED double switch, it reduces the amount of wiring for multiple gates and reduces the brackets needed for mounting the switches.
