![](/sites/default/files/styles/product_image/public/product_images/Iscar2SideProfiling.jpg?itok=O7pXUale)
Iscar Metals Inc. says its 11mm profiling insert does the job of a bigger one, thus enabling finer-pitch cutters for smoother profiling and lower chip loads. On a 2.00"-dia. cutter, for instance, six of the new HELIDO H400 RNHU 1205 inserts can reportedly fit in a pitch circle that normally accommodates just five standard 12mm inserts. Key applications include die and mold applications and blade profiling for the aerospace and power generation industries. It should be preferred wherever standard 12mm profiling inserts are used. Thehe design secret of the H400 RNHU 1205 insert is that it isn't quite round. Each face has four 0.236" radius cutting edges separated by a flat. The result is that the insert itself measures just 0.433" across and it performs like one 0.039" larger. The smaller the insert, the more you can fit into a given-size pitch circle. Depending on priorities, the user can translate this difference in diameter to higher table feeds, finer finish or longer edge life. Made from extra-tough SUMO TEC grades, the inserts are double sided, with each edge providing a 120 degree active area. The adjacent flats prevent insert rotation in the HELIDO cutter's rigid dovetail seat pocket. Despite the negative axial orientation needed to create a double-sided insert with its extra edges, the cutting presentation angle is 10 degrees positive as in standard round profiling inserts. Cutters for the new inserts feature coolant delivery to each individual insert, extending edge life even when running difficult stainless steel or superalloys. Insert grade choices are available to cover steel, superalloys and stainless steel.
- coolant
- flat ( screw flat)
flat ( screw flat)
- pitch
pitch
- profiling
profiling
- superalloys
superalloys
