HELIDO Trigon line expands with new tools & insert geometry
The HELIDO Trigon JET Line is a new family of indexable milling tools from ISCAR that features internal coolant channels for precise coolant delivery to the active cutting edge. These tools are primarily designed for machining with high pressure coolant (HPC); however, they can also be effectively used with standard pressure coolant, whether in wet or dry machining.
May 22, 2026
HELIDO Trigon line expands with new tools & insert geometry image
Helido Trigon Line
The new family comprises a group of 90° tools, available in the following design configurations:
  1. Exchangeable end milling heads with FLEX-FIT threaded adaptation
    Diameter range:
    Metric line – Ø32 and Ø40
  2. Face mill with a central bore (shell mills)
    Diameter range:
    Metric line – Ø50, Ø63, and Ø80
    Imperial line – Ø2.0”
  3. In addition, a new double sided HELIDO Trigon insert, designated H690 WNHU 07…FN P, features an innovative cutting geometry specifically developed for milling non-ferrous materials, further enhancing the family’s capabilities in ISO N applications.
Insert features
• Specially designed cutting geometry for milling non-ferrous materials.
• Six indexable, sharp cutting edges.
• Polished rake face.
Tool features
• High pressure coolant supply with precise flow directed to each active cutting edge.
• Compatible with both existing and new trigonal inserts of 07 size.
• Incorporates the proven design features of HELIDO Trigon milling cutters with the HPC option:
⁃ Accurate design ensures a true 90° profile, maintains high surface finish, and minimizes mismatch during multi pass shoulder milling.
⁃ Ramp down milling capabilities, including ramping by helical interpolation.
⁃ Robust pocket structure for secure clamping.
⁃ Protective coating to improve tool body durability and provide a high tech appearance.
