HF 120.4 High-Speed Spindle
IBAG North America offers the HF 120.4 high-speed spindle for Haas and other leading machining centers, delivering up to 42,000 rpm, 16kW and equipped for HSK40 and BT30 Tooling. The HF 120 is ideal for production manufacturing in aerospace, medical, mold and die machining and can be used in hardened steels, aluminum, brass, copper, graphite and various plastics.
This high-speed spindle can be installed into new and existing Haas 40-taper vertical and horizontal machining centers and offers full ATC integration for HSK or BT tooling. Standard options include oil-mist bearing lubrication, grease packed bearing lubrication, 1,000-psi coolant through the spindle, tapping and orientation. Installation package requires no permanent modification of machine.
