High-Pressure Coolant Systems
Four high-pressure coolant systems from machine tool equipment and accessory supplier CNC Indexing & Feeding Technologies each are engineered to match the production and economic requirements of differing manufacturing environments. For any manufacturer, the addition of high-pressure coolant capability increases productivity by enabling use of increased feeds and speeds, boosting workpiece quality and surface finish, and reducing manufacturing costs via increased tool life.
The HPC-400 HPCS is ideal for lathe and vertical mill applications and for shops that have a limited budget but seek the advantages of high-pressure coolant. The system's 8 gpm gear pump for water-based coolant is adjustable from 75 psi - 427 psi, and an on-board transfer pump is standard.
The HPC-1000system offers versatility in applications on horizontal and vertical milling machines as well as lathes, and can be used in conjunction with other manufacturing equipment. The system's 8 gpm, 7.5 hp gear pump system for oil- and water-based coolant is adjustable from 75 psi – 1,000 psi. An on-board transfer pump, 37-gallon reservoir tank and 4 port outlets are standard.
The HPC-1500 HPCS achieves the higher flow rates needed to utilize tools with large coolant orifices. The system's 8 gpm, 7.5 hp gear pump handles either oil- or water-based coolant and is adjustable from 75 psi – 1,500 psi. The unit features an on-board transfer pump, 37-gallon reservoir tank and four port outlets.
The HPC-2000, CNC Indexing's largest standard high pressure coolant system, employs oil- based coolant only and is ideal for CNC Swiss lathe machine tool applications. The system's 6 gpm, 10 hp gear pump is adjustable from 75 psi - 2000 psi, and the unit features an on-board transfer pump, 37-gallon reservoir tank, eight port outlets, and an oil chiller.
In addition providing four different standard high pressure coolant systems, CNC Indexing also can custom-build systems tailored to specific production needs, such as those offering 2,500 psi and higher with multiple preset pressures.
Steve Smith, president of CNC Indexing & Feeding Technologies, said, "Our company's comprehensive selection of high-pressure coolant systems will enable any shop to take advantage of the productive and economic advantages of high-pressure coolant technology."
