HiTech Rotary-Dress Diamond Dressing Rolls
Rotary-dress diamond dressing rolls feature highest repetition accuracy at lowest dressing costs. Recommended for high-precision components such as bearing tracks, valves, gear wheels, turbine blades or turbochargers. Precision diamond dressing rolls HiTech rotary-dress are manufactured in the following versions, depending on the machining task.
HiTech rotary-dress diamond dressing rolls from Lach Diamond, diamond tool manufacturer in Grand Rapids/Michigan, automate dressing processes in serial production while optimizing the use of machine capacity.
Precision diamond dressing rolls HiTech rotary-dress are manufactured in the following versions, depending on the machining task:
Sintered, negative
- Set or handset diamond coating
- CVD edge reinforcement
Electroplated, negative
- Randomset or handset diamond coating
Electroplated, positive
- Randomset diamond coating
