HJ-400 Horizontal CNC Lathe
Okuma introduces its new HJ-400 horizontal CNC lathe. This machine offers many of the advantages of the company's GENOS lathe series with a FANUC control, providing an affordable, entry-level lathe with exceptional flexibility. This machine tool can be equipped with an extended bed to accommodate a variety of workpieces for enhanced flexibility and throughput.
Built on a one-piece, cast iron base with a horizontal way system and hand-scraped headstock and tailstock mounting surfaces with two-point bearing support, this machine provides stability, rigidity and accuracy for a variety of applications. A gearless spindle reduces vibration and heat, minimizing thermal deformation for maximum productivity.
A user-friendly design maximizes productivity by allowing effortless workpiece loading and unloading and easy access to tooling. Chuck and tailstock controls are located at the front of the machine. A right discharge, hinge chip conveyor is standard.
  • chuck
    chuck
  • lathe
    lathe
