HU100A-5XLL Horizontal Machining Center
HU100A-5XLL Horizontal toolchanger. See automatic toolchanger." title="CNC machine tool capable of drilling, reaming, tapping, milling and boring. Normally comes with an automatic toolchanger. See automatic toolchanger." aria-label="Glossary: machining center">Machining Center
Mitsui Seiki's new 2500mm HU100A-5XLL Horizontal Machining Center is now available and designed for machining large, complex, and heavy (up to 6600 lbs.) hard metal parts.
Mitsui Seiki's new 2500mm HU100A-5XLL Horizontal toolchanger. See automatic toolchanger." title="CNC machine tool capable of drilling, reaming, tapping, milling and boring. Normally comes with an automatic toolchanger. See automatic toolchanger." aria-label="Glossary: machining center">Machining Center is now available and designed for machining large, complex, and heavy (up to 6600 lbs.) hard metal parts.
"We built several custom engineered machines with similar configurations and attributes; it made sense for us to add the HU100XLL to our standard product line," says Mr. Thomas Dolan, Mitsui's Vice President of Marketing and Sales. "The custom engineered machines were supplied to primarily aerospace, power generation, refrigeration, and mold and die parts manufacturers as all of these industries have fundamental common requirements for machine rigidity and stiffness for low frequency machining and high accuracy. We expect demand for this type of rugged, 5-axis equipment to accelerate over the next five years."
The HU100A-5XLL offers an X, Y, Z working envelope of 2500mm x 1750mm x 1400mm (98.4" x 68.9" x 55.1"). The A and B tilting and rotating trunnion table axes represent the 4th and 5th axes of motion. The standard spindle offering is a 50 taper, although many manufacturers taking extra heavy roughing cuts in titanium and tough steels could opt for the HSK 100 or HSK 125 spindle with extra high torque of 3332Nm (2457 lb.-ft.).
The FMS-ready machine has a pallet size of 1700mm x 1000mm (66.9" x 39.4") and accommodates weight up to 3000kg (6600 lbs.). The automatic toolchanger accommodates 360 tools with lengths up to 500mm (19.6"), diameters to 305mm (12"), and weights of 30kg (66 lbs.).
