Huot Workstation
Huot Workstation
Designed with a machine shop environment in mind, the new Huot Workstation provides a solid, stable work location with plenty of functional top surface space.
September 13, 2012
Designed with a machine shop environment in mind, the new Huot Workstation provides a solid, stable work location with plenty of functional top surface space. Everything you need to be productive is stored and organized right at your fingertips, with the ability to lock it up when finished.
The top two drawers utilize welded columns with dividers every 1" for customizing storage and organization. The 4" drawer is open for larger tools and miscellaneous items while the bottom 6" drawer holds up to 30 toolholders depending on taper size. Cabinet is pre-drilled on both sides to mount a Huot tool changing vise (sold separately) horizontally or vertically (shown). Locking doors protect against chips and debris and keep valuable tools secure.
Made from heavy duty welded steel and all drawers use full extension ball bearing slides for complete accessibility. Cabinet pockets allow for movement with a forklift.
Dimensions are 34" L x 22 ¾" W x 39" H. Shipping weight is 285 pounds.
