HY-PRO CARB 3D and 5D Through-Coolant Drills
OSG Tap & Die Inc.s HY-PRO CARB 3D and 5D Drill Series is designed for a multitude of materials. Its unique point and flute geometry reduce thrust forces and chip size. Higher feeds and metal removal rates may be achieved with the addition of coolant-through capabilities.
The HY-PRO CARB 3D and 5D Drill Series' applied multi-layered TiAlN coating resists thermo-cracking from heat, thus improving wear resistance over conventional coatings. Lastly, the common DIN shank sizes not only improve rigidity, but also reduce the number of tool holders needed to accommodate them.
  • shank
    shank
  • tap
    tap
  • titanium aluminum nitride ( TiAlN)
    Often used as a tool coating. AlTiN indicates the aluminum content is greater than the titanium. See coated tools.
  • wear resistance
    wear resistance
