Hydraulic Work Supports
Carr Lane Roemheld offers a wide range of hydraulic work supports that automatically adjust to the workpiece height, then lock securely to become fixed rests. Available in spring-advanced, fluid-advanced and air-advanced types, these work supports are extremely compact, starting at just 1" diameter, with maximum pressures up to 7,500 psi.
April 18, 2016
Carr Lane Roemheld offers a wide range of hydraulic work supports that automatically adjust to the workpiece height, then lock securely to become fixed rests. Available in spring-advanced, fluid-advanced and air-advanced types, these work supports are extremely compact, starting at just 1" diameter, with maximum pressures up to 7,500 psi. These high-performing supports are designed for 500,000 cycles, and come in more than 60 different standard sizes and styles, with supporting forces from 145 to 23,000 lbs.
To learn more, visit the Carr Lane Roemheld website here.
