HydroChuck Grind-A and HydroChuck Grind-M Chucks
MAPAL offers hydraulic chucks specially for tool grinding machines, the HydroChuck Grind-A and the HydroChuck Grind-M. The advantages of MAPAL's hydraulic expansion technology can thus now also be used for tool grinding.
February 20, 2017
MAPAL offers hydraulic chucks specially for tool grinding machines, the HydroChuck Grind-A and the HydroChuck Grind-M. The advantages of MAPAL's hydraulic expansion technology can thus now also be used for tool grinding. Both chucks ensure high-precision clamping and reproducible dimensional accuracy during grinding. They are designed for the shank tolerance h6 and score with their low wear and the associated high cost-effectiveness.
In addition to its high radial runout accuracy, the HydroChuck Grind-A with automatic workpiece clamping is characterised in particular by its energy-efficient function. The workpiece is clamped by means of a cup spring pack. The hydraulics of the machine are only required for releasing the workpiece. The hydraulic chuck is set and adjusted with μ-precision using two dial gauges in just a few minutes.
Wobble can be compensated, resulting in maximum workpiece precision. In addition, a uniform material removal and high surface finish quality can be assured. During the design, attention was paid to minimum tool restriction and hence the best possible grinding wheel runout. The new chuck offers not only reduced wear of the grinding wheel but also very close geometries, a constant quality and form/dimensional accuracy of the workpiece. The hydraulic expansion unit can be changed separately, the chucks can be completely overhauled.
In addition to the HydroChuck Grind-A, MAPAL also offers the new HydroChuck Grind-M for manual workpiece clamping. The tool to be ground is clamped here manually using a hexagon head screw. This chuck also allows the
benefits of the hydraulic expansion technology to be used for tool grinding.
  • grinding wheel
