HydroFlow Refractometer
Eriez HydroFlow offers a complete line of the most commonly used test equipment and titration kits for keeping metalworking fluids in peak operating condition.
Eriez HydroFlow offers a complete line of the most commonly used test equipment and titration kits for keeping metalworking fluids in peak operating condition. These hand-held instruments accurately measure fluid conditions so corrective actions can be taken before major problems arise.
Maintaining the proper concentration in industrial fluids is extremely important to maximize the performance and value of the fluid. If the fluid is run too lean, tool life and fluid life can drop dramatically. If the fluid is run too rich, money is being wasted.
The Eriez HydroFlow Automatic Temperature Compensating Refractometer allows plant operators to quickly determine the concentration of metalworking coolants and cleaners, heat-treating fluids, water-based hydraulic fluids, and even plating baths. This simple yet rugged device is portable, and requires no batteries. Its large, easy-to-read scale is available in two ranges: 0-10 degrees Brix and 0-32 degrees Brix.
These handy fluid recycling instruments are designed for most metalworking operations, including cutting and grinding fluids, synthetic machining fluids, plating and acid baths, cleaner baths, water-based hydraulic fluids, die lubricants and chromating solutions.
