HydroFlow Reversible Liquid Vacuums
Eriez HydroFlow Reversible Liquid Vacuums offer a simple, speedy solution to the usually time consuming and bothersome task of removing spent coolants, waste fluids and oils from machine sumps, reservoirs and storage tanks.
Eriez HydroFlow Reversible Liquid Vacuums offer a simple, speedy solution to the usually time consuming and bothersome task of removing spent coolants, waste fluids and oils from machine sumps, reservoirs and storage tanks. These units will also discharge fluids out of the drum into a separate container, if desired, with just the turn of a knob.
Lower quality competitive vacuums frequently do not have the ability to perform satisfactorily. They are often cumbersome, loud and not built to stand up to the harsh demands of an industrial environment. High quality, compact Eriez HydroFlow Reversible Liquid Vacuums operate quietly, efficiently and reliably. They are incredibly durable and small enough to fit in the palm of the user's hand.
Reversible Liquid Vacuums operate on shop air and attach to the small bung on a standard drum. With only one moving part, they require no maintenance.
Each Eriez HydroFlow Reversible Liquid Vacuum comes with everything required to start using it immediately. Every kit includes a venturi unit, 1+" x 10' (38mm. X 3 m L) suction hose, drum standpipe adapter, quick disconnect fittings, air control valve, safety shut-off valve and aluminum wand.
